int ix = 0;
void scrolling() {
uint32_t start = 598500;
String text = "000000000000000000000";
for (int ix = 0; ix < 20 - 5; ix++) {
uint32_t charpos1 = ((uint32_t)((uint32_t)text.charAt(ix) - (uint32_t)42) * (uint32_t)78UL * 100UL * 3UL);
uint32_t charpos2 = ((uint32_t)((uint32_t)text.charAt(ix + 5) - (uint32_t)42) * (uint32_t)78UL * 100UL * 3UL);
String myScroll = text.substring(ix, ix + 5);
for (int stringx = 0; stringx < 78; stringx++) {
transparentTileImage( start + charpos1 , bgstart, 6 * 78 - stringx , 165, 78, 100, 77 - stringx, 0xFFFFFF);
DrawString( 598500 , 78 - stringx, 165, 78, 100, myScroll, false, true);
transparentTileImageRight( start + charpos2 , bgstart, 0 , 165, 78, 100, stringx, 0xFFFFFF);
delay(10);
void DrawString( uint32_t check, int x, int y, int width, int height, String text, bool compare, bool transp) {
int lengthl = text.length();
for (int l = 0; l < lengthl; l++)
uint32_t charpos = ((uint32_t)((uint32_t)text.charAt(l) - (uint32_t)48) * (uint32_t)width * height * 3);
// uint32_t charpos = ((uint32_t)((uint32_t)text.charAt(l) - (uint32_t)48) * (uint32_t)width * height * 3);
if (text.charAt(l) == '.')
charpos = ((uint32_t)((uint32_t)11) * (uint32_t)width * height * 3);
else if (text.charAt(l) == ' ')
charpos = ((uint32_t)((uint32_t)12) * (uint32_t)width * height * 3);
if (transp)
transparentImage( check + charpos, bgstart, x + ( l * width), y, width, height, 0xFFFFFF);
else
notransparentImage( check + charpos, bgstart, x + ( l * width), y, width, height, 0xFFFFFF);
lasttext = text;
uint32_t startdata = 0x151000;
void transparentImage(uint32_t startpic, uint32_t startbackground, int x, int y, int width, int height, uint32_t tcolor) {
tft.setWindow(x, y, x + width - 1, y + height - 1);
//read background clipping
// File f = SPIFFS.open( "/test.bin", "r");
char *buf = (char*)malloc(width * height * 3);
char *temp = (char*)malloc(width * 3);
unsigned long offset = 0;
for (int i = 0; i < height; i++) {
unsigned long offsetbg = startbackground + ((y + i) * 480 * 3 ) + (x * 3) ;
memcpy(buf + (i * width * 3), data + offsetbg, (width * 3) );
unsigned long offset = startpic + i * width * 3;
//spi_flash_read(startdata+offset, (char*)temp, width*3);
memcpy(temp, data + offset, (width * 3) );
for (int h = 0; h < width * 3; h = h + 3)
uint32_t bp = temp[ h];
bp = (bp << 8) | temp[h + 1];
bp = (bp << 16) | temp[ h + 2];
if (bp >= 0x111111 || y + i > 272) {
buf[width * i * 3 + h] = temp[h];
buf[width * i * 3 + h + 1] = temp[h + 1];
buf[width * i * 3 + h + 2] = temp[h + 2];
vspi->beginTransaction(SPISettings(spiClk, MSBFIRST, SPI_MODE0));
digitalWrite(5, LOW); //pull SS slow to prep other end for transfer
vspi->writeBytes((uint8_t*)buf, width * height * 3);
digitalWrite(5, HIGH); //pull ss high to signify end of data transfer
vspi->endTransaction();
// f.close();
//Serial.println("test");
free(buf);
free(temp);
void transparentTileImage(uint32_t startpic, uint32_t startbackground, int x, int y, int width, int height, int clipping , uint32_t tcolor) {
tft.setWindow(x, y, x + (width - clipping) - 1, y + height - 1);
char *buf = (char*)malloc((width - clipping) * height * 3);
char *temp = (char*)malloc((width - clipping) * 3);
memcpy(buf + (i * (width - clipping) * 3), data + offsetbg, ((width - clipping) * 3) );
memcpy(temp, data + offset, ((width - clipping) * 3) );
for (int h = 0; h < (width - clipping) * 3; h = h + 3)
uint32_t bp = temp[h];
if (bp >= 0x111111...
jobinpthomas1
PJK
Arnov Sharma
