// Parking Helper
// by Hari Wiguna, 2015
// Heavily based on Arduino Ping example
const int ON = LOW;
const int OFF = HIGH;
// Distance sensor is HC-SR04
const int pingPin = 12; // TRIG
const int echoPin = 13; // ECHO
int prevBar = 0;
void setup() {
//-- Initialize led bargraph pins (D2..D11) --
for (int i = 0; i < 10; i++)
pinMode(2 + i, OUTPUT);
digitalWrite(2 + i, OFF);
//-- Initialize distance sensor pins --
pinMode(pingPin, OUTPUT);
pinMode(echoPin, INPUT);
void loop()
// Send out a 5 microsecond pulse
digitalWrite(pingPin, HIGH);
delayMicroseconds(5);
digitalWrite(pingPin, LOW);
// Listen for that pulse to come back
long duration = pulseIn(echoPin, HIGH);
// convert the time into a distance
long cm = microsecondsToCentimeters(duration);
// Convert cm to bar graph
int bar = map(cm, 10, 70, 9, 0);
// only update bar graph if value changed
if (bar != prevBar) {
digitalWrite(2 + prevBar, OFF);
digitalWrite(2 + bar, ON);
prevBar = bar;
delay(100);
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
wils Nico
PJK
Yeah, it makes the code easier to read and modify. You got to show me the finished project, take a video or do a show-n-tell at MakeShift!
