Horizontal Travel Robot Arm
Computer Vision enabled Pick & Place Robot
Public Chat
My objective was to deliver practical movement of objects for lightweight use cases.
This is a very flexible design that can be strengthen and improved easily, and as you can see in the videos, it can be Computer Vision enabled quite easily.
It has the ability to be a very low cost and functional design, with ability to move objects close to 1 meter and very reliable for small items.
Overview of Project: https://medium.com/@pacogarcia3/computer-vision-pick-and-place-for-toys-using-raspberry-pi-and-arduino-68a04874c039
My objective was to deliver practical movement of objects for lightweight use cases.  This is a very flexible design that can be strengthen and improved easily.
I have effectively tested this to 1m and it is extremely reliable for light objects.
It works extremely world with Single Camera Computer Vision.
Summary Specs:
0.88 lbs (0.4 kg) tested max payload Vertical travel Z-axis: 6.8 inches (17.3 cm) Reach Y-axis: 10.2 in (26 cm) Customizable Horizontal travel X-axis (3.3 ft (1 m) as tested.
Project Overview:
Machine in Action:
https://youtu.be/f3s_uub4P6Q
Capability Specs:
https://www.fdxlabs.com/products/horizontal-travel-robot-arm-hta0/hta0-tech-specs/
Bill of Materials, Kit, Assembly Instructions:
Code:
https://github.com/pacogarcia3/hta0-horizontal-robot-arm
P1 - Gripper Hand C2 v3.stl
Standard Tesselated Geometry - 354.96 kB - 04/10/2019 at 01:43
Download
P1 - Gripper Hand Vertical C2 v3.stl
Standard Tesselated Geometry - 358.29 kB - 04/10/2019 at 01:43
Download
P1 - Arm incl Bearings.stl
Standard Tesselated Geometry - 479.28 kB - 04/10/2019 at 01:43
Download
P1 - Servo Base.stl
Standard Tesselated Geometry - 66.49 kB - 04/10/2019 at 01:43
Download
P1 - Rotating NEMA Holder.stl
Standard Tesselated Geometry - 58.58 kB - 04/10/2019 at 01:43
Download
View all 14 files
View all instructions
Boluwarin001 wrote 08/28/2019 at 18:05 point
I'm interested in creating something like this for my final year project! Any tips sir?
