1Order parts
Get an assembled and tested board from www.powerdesigns.ca
Order components to build a powerstage according to your needs. See the datasheet for examples for 400V 300A operation.
Need a quicker/simpler/reliable turnaround? You'll be able to order a fully assembled and enclosed motor controller when the beta test stage is done (and jump to stage 3)!
2Assemble the motor controller
4Use your motor!
Now you can move on to the next step to integrate Axiom into your application, preferentially over CANbus. Moving a boat? a an EV? a big machine?
The sky is the limit!
I have a MP202/150 outrunner it is a brushless dc permanent magnet motor - my battery pack is 140 volt nom (130 to 150) I would like to buy a controller - or at least all the parts., How do I do that ? Is that even possible? also I hate having to do any sort of coding as I am just not that smart - The motor is for my EV conversion of a 1986 Honda City convertible - I used a kelly controller but the motor keeps stalling when I drive down the road -
- https://www.freerchobby.cc/collections/brushless-motor/products/mp202150-70kw-170kg-thrust-120nm-high-torque-for-mega-drone-aircraft
