The current iteration of Democracycam is designed to opportunistically join a shared open WiFi network with other Democracycams and automatically distribute any photos taken across the network as soon as they are captured.
This is done in the simplest way I could come up with, using built-in Linux functionality whenever possible and using the excellent Forban software to handle the distribution of images.
Currently the only code provided is for creating a very basic (and not very good) image preview & capture using the Raspberry Pi-based hardware, documentation on the rest of the configuration is yet to come.
At some point other devices & platforms could be supported, but I have some ideas that require lower-level access to the hardware than I think is possible using off-the-shelf devices like smartphones, etc.
jason.gullickson
Pavel Zhovner
William Glover
Sanne 'SpuQ' Santens
James Pilgrim
Today, in 2023 your system would be very Usefull
We are at the fate of a WWIII and we see in real time Israël cut all communication in Gaza so the WEST don't know what killing has taken place there.
So your system can't be using radio like Wifi it would be spoted and probably destructed.
I'd say there is no much left to communicate safely. Maybe a laser could aim far enough to be seen and copy the records of your device ? But then who/how would someone pick it up ?
The radio/internet Lock also happened in Paris in some situation, to block the population from organizing against the regime decisions.
Your project resemble to a spy project, or that could be used by any foreign country in an attack to disorganize a regime, right or wrong.
I happend to have an interest in your search for an even heartache situation: in case of a 4Nat, where there no more radio to emit, no more power to energize. This happened for one whole week in the french west indies in 2017 XMartin.
#HAND hacker against natural disaster has born from that.
You can contact for any reason.
I am MARSU from the FdG
