Time for a second generation
12/06/2016 at 16:03 • 0 commentsI learned a lot from the first attempt at developing this device, but so much has changed that I think it's time for a new device with a similar mission.
I've been noodling on exactly what that is, and I have a few ideas I like. Once I get some traction I'll be starting a new project and I'll post a link here.
Software Alternatives & jsfs
07/15/2014 at 19:10 • 1 commentI'm working on another project which is developing a distributed filesystem that runs under node.js. It may be a good fit for the underpinnings of Democracycam if I can make node.js perform well on the Raspberry Pi (without severe resource consumption).
Still in the testing phase, but I thought I'd mention it in case anyone was looking down this path.
Case Options
04/14/2014 at 14:07 • 0 commentsGave the Adafruit-designed printed camera case a try, it's very well-designed, but doesn't quite fit the hardware I have. I'm planning to pick-up a complete set of hardware from Adafruit for two cameras so I can build some field-ready units to really test and debug the software, which should run about $300.00.
Now just to find a wealthy benefactor to underwrite the R&D ;)
Laziness Pays Off
02/23/2014 at 13:44 • 0 commentsLooks like Adafruit has done a lot of the work for me while I took a break from this project. The most time-consuming bits when I started out were fighting through getting the touchscreen to work with the camera, and it looks like they've wrapped all that up in a nice set of instructions here:
http://learn.adafruit.com/adafruit-pitft-28-inch-r... They also offer a board that could take the place of the one I'm using (seems to work in a similar fashion, but has the software/drivers/kernel stuff figured out for you): http://www.adafruit.com/products/1601
Finally the O/S support for the Pi camera has improved much, so now it looks like getting it to work is simply a setup option, sweet!
Based on all this I'm going to re-cobble my hardware and put together a software stack based on what's now available. Once that's done I'll be turning my attention to the parts of the software that are not off-the-shelf (handling the network transparently and the Forban configuration). I may also be able to pick up a second camera worth of hardware now that I have a convenient place to buy it all...
Hardware-wise the case and battery still need to be sorted out, so there's work to do. I also want to investigate some of the other tiny ARM platforms that have come out since I originally embarked on this project, as well as other types of devices that might participate in the network (storage-only nodes, mobile network uplinks, etc.)
