1Step 1
Check you have the necessary hardware components and have installed the necessary packages.
2Step 2
Assemble the greenhouse structure.
3Step 3
Plant the seeds/bulbs/sprouts in the planter.
4Step 4
Position the sensors and response systems and feed the connection cables out of the greenhouse.
5Step 5
Connect the components to the RaspberryPi using the Raspberry Pi header.
6Step 6
Download the binary software files from GitHub.
7Step 7
Search for and connect the Raspberry Pi and your access device to the hidden wifi network.
8Step 8
Access the SmartGreenhouse webpage and run the system
islasummer
