I had some time over the holidays, so I made some progress on the PCB. A new footprint for the buttons and for the screen connector, routed everything except for the screen. Next I will need to add a truckload of capacitors for the screen, and bunch of vias for the display signals. I think I will go with SPI, because it's two resistors less, it's faster, and I have the pins for it anyways. The whole PCB is 32x32mm right now.
Is this stable? I know press-fit contacts:
https://www.mill-max.com/new_products/detail/164
They are pretty stable, sometimes better than soldered pins, because there can't be a cold solder joint and no solder joint can break, if there is mechanical stress at the pin.
I wonder if this works with standard pin headers as well, e.g. with 0.9 mm holes. But might be difficult to mount them. There are special tools for these press-fit pins and the thicker round cylinder after the square or hex pin helps to insert it exactly at the same depth for all pins.
That is interesting what is the offset?
I really have no idea, it's a core part in Fritzing.
The pin header is drunk.
This way no soldering required.
