We are working on the LEGO®-compatible Marble Run building blocks / bricks for up to 12 mm balls. But sometimes it helps to have a few specialty parts for curves, gentle slopes and smooth transitions.
LEGO® bricks shown in the build examples are not part of the set. LEGO® is a trademark of the LEGO Group of companies which does not sponsor, authorize or endorse this site.
building bricks
Here is a list of the actual building bricks:
- marble_brick_06x06_twister.STL
- marble_brick_04x04_twister.STL
- marble_brick_04x04_split.STL
- marble_brick_04x04_funnel.STL
- marble_brick_04x04_curve_sloped.STL
- marble_brick_08x08_twister.STL
- marble_brick_04x04_curve.STL
- marble_brick_04x04_cross.STL
- marble_brick_12x12_twister.STL
- marble_brick_02x02_tunnel.STL
- marble_brick_02x04_looping.STL
- marble_brick_02x04_track.STL
- marble_brick_02x04_track_sloped.STL
- marble_brick_02x16_track_flex.STL
- marble_brick_02x02_curve.STL
- marble_brick_02x02_curve_sloped.STL
- marble_brick_02x02_startend.STL
- marble_brick_02x02_track.STL
- marble_brick_02x02_track_sloped.STL
- marble_brick_02x02_cross.STL
Download
download the STL files of the Marble Bricks under :
https://pinshape.com/items/49194-3d-printed-lego-marble-run-brick-set-basic
MasterOfNull
szynyszyl
