Prototype_Enclosure_Body.stl
The 'walls' of the prototype enclosure. Standard STL mm format. CC BY 4.0
Standard Tesselated Geometry - 65.02 kB - 08/15/2019 at 21:22
Download
Prototype_Enclosure_Assembly.rsdoc
The assembly of the prototype enclosure. Created in Design Spark Mechanical. CC BY 4.0
rsdoc - 893.43 kB - 08/15/2019 at 21:21
Download
Prototype_Enclosure_Mount Plate.stl
The mounting plate for the circuit board. Standard STL mm format. CC BY 4.0
Standard Tesselated Geometry - 280.55 kB - 08/15/2019 at 21:21
Download
Prototype_Enclosure_Graphic.svg
The top surface of the prototype enclosure. Designed to be cut/engraved on a laser cutter. Best edited in InkScape. CC BY 4.0
svg+xml - 14.37 kB - 08/15/2019 at 21:20
Preview
Enclosure Matrix.xlsx
CC BY 4.0
sheet - 17.80 kB - 08/14/2019 at 16:37
Download
Megunolink.ino
This is two of two arduino sketches that interface with the MCP39F511A eval board and the MegunoLink interface. CC BY 4.0
ino - 5.07 kB - 05/13/2019 at 16:11
Download
Power_Monitor_Fast.ino
This is one of two arduino sketches that interface with the MCP39F511A eval board and the MegunoLink interface. CC BY 4.0
ino - 13.26 kB - 05/13/2019 at 16:11
Download
Power Monitor.mlpz
This is the Megunolink project that we use to run our MCP39F511A power monitor. CC BY 4.0
mlpz - 30.20 kB - 05/13/2019 at 16:10
Download
