A low cost, low power, internet connected temperature monitor and alarm
Fridge Monitor & Alarm SSFD.docxdocument - 55.56 kB - 04/28/2019 at 11:32 |
Schematic.pdfAdobe Portable Document Format - 83.63 kB - 04/28/2019 at 11:32 |
Hardware Block Diagram.pngPortable Network Graphics (PNG) - 30.23 kB - 04/27/2019 at 17:32 |
I've added a very rough schematic to get started. Before I commit to the temperature sense and light sense circuit I will purchase a few parts to test them out.
I've also added a system specification and function description document to explain how the system works. It's mostly for me to remember why I chose certain resistor values and components.
These files will be regularly updated as I make changes - they're very rough.
I came up with a simple hardware block diagram and chose a few parts that will make up the main system components. I think I should remove low cost from the title because I don't think it will be as inexpensive as I was hoping.
I thought about various configurations that the system could be in and decided that I wanted to put everything in a single package. This may cause issues in the future as batteries do not run well in cold and I'm not sure how well wifi will penetrate the walls of a fridge. I will try to put everything in a single package for easy installation and if there are issues then I will try to work around it or change the design.
I've attached a basic hardware block diagram and I would like the system to following way:
I chose to use an RTD over a cheaper type of temperature sensor to have some decent accuracy since this is for food safety.
I have decided to use the ATwinc1500 wifi module over ESP8266 and its derivatives due to a lower current consumption in idle mode.
I will probably use the ATmega328pb MCU since I already have libraries made and I am comfortable with it. For a final product the MCU should probably be optimized for what the system actually needs.
