I came up with a simple hardware block diagram and chose a few parts that will make up the main system components. I think I should remove low cost from the title because I don't think it will be as inexpensive as I was hoping.
I thought about various configurations that the system could be in and decided that I wanted to put everything in a single package. This may cause issues in the future as batteries do not run well in cold and I'm not sure how well wifi will penetrate the walls of a fridge. I will try to put everything in a single package for easy installation and if there are issues then I will try to work around it or change the design.
I've attached a basic hardware block diagram and I would like the system to following way:
- Achieve lowest power possible by turning things off or entering sleep modes
- Wake up periodically to test temperature and battery voltage and store data to memory. If there is a temperature issue then wake up on a higher frequency period.
- When the door opens, I want the system to wake up and display the current temperature
- Access to data through a phone app
- phone app to change alarm thresholds for temperature and battery discharge level
I chose to use an RTD over a cheaper type of temperature sensor to have some decent accuracy since this is for food safety.
I have decided to use the ATwinc1500 wifi module over ESP8266 and its derivatives due to a lower current consumption in idle mode.
I will probably use the ATmega328pb MCU since I already have libraries made and I am comfortable with it. For a final product the MCU should probably be optimized for what the system actually needs.
