ARMduino2
An ARM Cortex M0 dev board in the convenient Arduino UNO form factor
ARMduino_X.pdf
Schematics
Adobe Portable Document Format - 144.99 kB - 05/13/2019 at 17:17
Preview
Sergio Costas wrote 10/21/2020 at 13:45 point
I don't know if the board has it, but it would be a good idea to have a jumper that, when removed, allows to connect a tester to measure the current consumption. But, important, only the consumption of the ARM and peripherals connected to the buses, but not the USB programming chip, LEDs and other things (this is: everything that in a "production device" you won't have), and thus allow to use this as a testbed/development board for low-power devices.
