Design files
05/07/2019 at 13:03 • 0 commentsDesign files uploaded to github https://github.com/bobricius/Ledcade
PCB for order at Dirty.pcbs
05/06/2019 at 19:25 • 1 commentIf you think ... this board is expesive ... no ... only http://dirtypcbs.com accept multiple boards without additional charge, I try another "cheap" manufacturers RESULT > it is 90pcs boards = more than 100$
http://dirtypcbs.com/store/designer/details/bobricius/6290/rtm-zip
If you want order this board from dirtypcbs store do not forget chose 10x10cm 1.2mm board also you receive 10pcs boards !!!!
First blink
04/25/2019 at 22:00 • 4 commentsI am just uploaded compiled HEX, screen is reversed, I fix tomorrow, now I am exhausted.
from 2D board to 3D cabinet
04/25/2019 at 21:54 • 0 commentsFinishing some hours of soldering, not all fit perfectly,
there is some space for improvement in next release ;) -
manufactured boards
04/25/2019 at 21:50 • 0 comments -
Board allocation ...
04/25/2019 at 21:45 • 0 commentsI am not used any 3D program, all only imagined in my head.
