As the old steering wheel is designed for kids and will not withstand the acceleration of the motors and adults, it needs to reinforced with a 3D printed part. The files can be found on the files tab.
On the lower side, there are 2 inlets for aluminium parts with inner threads, that you can use to fasten the steel steering rod with 2 M6 screws:
On the top side, the original plastic steering wheel fits the 3D printed part perfectly. There are also 4 cable channels which can be used for the joysticks and the display and further accessories.
When everything is assembled you have a bobbycar with a stronger steering wheel:
Now, you can also print the display holder parts and mount a standard 2.2" SPI display:
For the throttle pedals, I used xbox 360 controller trigger buttons:
The RJ45 connector is used for the 3.3V to the display and the SPI pins. There is no actual ethernet on this cable, but it still looks like a "power over ethernet" system
To convert the bobby car to electric , I did remove the original plastic wheels and replaced them with 6.5" BLDC hub motors which can be found on hoverboards.
First, I used a saw to remove some plastic from there area where the original rear wheels were and made 2 aluminium plates, one with 2 grooves for the motors and a lot of screw holes.
The grooves and M8 screw holes are needed for the hub motors:
The aluminium plates are screw onto a wooden block, that is also mounted on the plastic frame of the original Bobby-Car.
The bottom of the whole Bobby-Car now looks like this:
The cutout in the middle is needed for the electronics, which will be added later.
Very cool project! I have questions (as well as some dead hoverboards):
Which VESC controllers are you using?
Are you using the original battery?
Is the code available?
