Mechanical build - front motors
A project log for Electric Bobby-Car
This projects converts a Bobby-Car (children's ride-on toy) to electric by using 4 Hoverboard motors, VESC controllers and an ESP32
peter-ptziPeter Pötzi • 04/28/2019 at 21:28•0 Comments
To convert the front wheels to electric, I first 3D printed adapters, which can be used to mount the motors on the plastic frame:
The aluminium parts reinforce the 3D print:
Together with the other part it looks like this:
Now it will just replace the original plastic steering system:
The original plastic part that holds everything together can still be used:
Also the steering is still done with the original 10mm bent steel rod:
