MACI cobot composed of 6 joints, 3 joints 100 Nm and 3 joints 35 Nm. The joints are controlled thanks to 3 ODrives. Each joint is composed of a brushless motor, an encoder AMT102-V (to see if I change for an AS5048) and a cycloidal reducer.
The 2 sizes of joints, the big one, 80mm of diameter and 100 Nm of torque. The smaller, 70mm of diameter and 35 Nm of torque.
Léonard Dabin
Luc JOB
Baird Bankovic
Ben Bokser
Can you share stl ? :)
