Iron Gauntlet SAO Gerbers. Unlike the Arc Badge the Iron Gauntlet actually had some changes to its design for the second and final run so you should use these. This requires 1204 Side View LEDs (1206 soldered on sideways could work) and appropriate value 0805 Resistors and of course a 2x3 Male header.
x-zip-compressed -
729.60 kB -
08/01/2020 at 04:32
This is the 3D Printed Spacer that goes between the top and bottom board. This is the 2020 Revision that fixes a potential short where the lanyard lobster claw shorts the programming headers.
x-zip-compressed -
166.67 kB -
08/01/2020 at 03:56
