Hotrod
A project log for FilaMecanum
3D printed hub, filament tires, Mecanum motion.
masterofnullMasterOfNull 05/03/2019 at 21:390 Comments
I modeled a new version for the purpose of actually building something!
This one is big enough to wrap the motor I have, is lower profile for less off-axis deflection but wider to allow more vertical flexing, has 60 filaments instead of 30, and now prints as one piece.
Now to add the #MPRT - Modified planetary robotics transmission drive to the inside.
That part still needs a little work.  I'm on it.  In the meantime, the source I'm starting with to produce what you see above...is up.
