The PowerCore is an Arduino (ATmega328p) dev board that I designed with an optocoupler, triac and integrated AC-DC power supply for easy phase fired control. You can read more about the PowerCore its development on my blog: http://bit.ly/2IWmm4C
The FluxLamp is a project based on the PowerCore dev board. It uses an inexpensive and commonly available halogen work lamp to create a soldering reflow oven. More about the FluxLamp as well as a build guide is available on my blog as well: http://bit.ly/2GWk3Mt
This project has been certified by Arrow and will launch on Indiegogo with enough interest. Fill out this form to be notified: https://goo.gl/forms/NL6RoZNbVZ8R6ZUR2
Please include reference to the open sources you used: https://github.com/dasaki/nanoreflowcontroller
