The conveyor belt model allow you to sort two types of discs. One of them has metal element inside and will be detect by inductive sensor. Another one is make only with plastic and only capacitance sensor will detect them.
Most of elements in our device was made on 3D printer. The conveyor has simple controller inside, based on STM32 and optoinsulation module. Controller translate the high voltage from PLC (24 V) to 3.3 V and drive all the modules on the device (disc ejector, actuators, stepper motor and so on).
In device there is also simple color sensor but now it is unprogrammed.
User can set two belt speeds (slow and fast) and stop the belt completely.
All actuators are based on servomotors. Working conveyor belt you can see on movie below:
This is first release of our product. In future we want to develop project and prepare new revisions.
ntembed
Krishna Mohan
Bill Brubaker
Curt White
mircemk
By working with a conveyor belt model, you can learn how to program PLCs to control the speed, direction, and position of objects on the belt. To further improve your skills in this area, it's important to avoid common mistakes when it comes to speech writing. Check out https://geekvibesnation.com/7-common-mistakes-to-avoid-in-speech-writing/ for some tips on how to write effective and engaging speeches that can help you communicate your ideas clearly and concisely.
