The analog watch is finally Working :-)
Some problems with the Locking of the Ports were causing the BMA Sensor to not work.
The solution was to change the Initialization order as follows:
- Initialize the Ports for the LEDs, so all LEDs are Off
- Initialize the BMA Sensor
- Lock the Ports
Now basic functionality is given. So it is time to test it.
