Refresh of the Pluto programmable digital watch from Lukas / carrotIndustries. Cheaply manufacturable in 2019.
We finally received everything. So we went at our local hackerspace, Electrolab, to solder the first prototype.
So we started to put solder paste on the PCB with a sharpened toothpick (0402 parts are a thing of beauty and a joy forever), following the really handy interactive HTML BOM.
We thought we would put the MSP430 MCU last since it is the largest part and it could interfere with the soldering of the other components.
First issue, probably a clearance problem. One of the two R2 pads was under the solder mask. We scraped it (yes with all the other passive components already placed of course, note for future self: never trust a quality control from a $2 PCB supplier). It seemed to take solder just fine.
Let's take a look at the datasheet shall we?
Always check your packages. Twice.
I ordered some samples from TI to get the first prototype running, with the correct VQFN package.
We had access to a professional computer-controlled reflow oven, devouring 16kW of power, but it was probably just a bit overkill for a single 24mm board. We were glad to be able solder everything with a hot air gun, soldering iron, and a lot of dexterity.
See you in the next log, hopefully with a working prototype!
Huh. I never was happy with the magnetometer in my pluto, I could never get it working. I might just build this, and see if its better!
How is the progress?
It's a great project and I looking forward to a log update about a prototype.
If you need help with the project, I may be able to support.
I just moved to Switzerland so I need a little bit of time to organize myself before starting projects again, but I will continue this one for sure!
The plastic (original) F-91W is my daily driver now and I am saving to take my paragliding licence (in CH that's mandatory, humans like their laws) and I would like to use it at my alti/variometer.
Thanks for the proposition, if we have too much issues I will contact you ;)
Welcome to Switzerland! Hope we meet at some meetups here.
There used to be Mini Maker Faire, but this year it didn't happen, but instead there was "Flick the World", there are open door at SGMK every Tuesday, the Fablab is organizing things once in a while, and there are some random things from time to time (I'm talking about Zürich here, other places have their own things.)
Thanks, interesting, I am from Lausanne, but I will visit Zürich at some point.
There is a list of events at http://wiki.sgmk-ssam.ch/wiki/Main_Page
We also added a low power pressure / temp / humidity sensor. More on that soon.
Do you have a link to the original project? Everybody but me seems to know what it was, but I somehow missed it.
https://github.com/carrotIndustries/pluto
Just click under the repo name after "forked from ..."
Oh wow, that is an awesome project! I'm looking forward to see what you make of it!
Nice!
I was put off by how difficult it was to source the magnetometer for the original Pluto PCB
I really hope you succeed with your project!
We already made the hardware redesign, and ordered the PCBs. Waiting for everything to get there to do the software work.
Thank you!
Yep thanks, we also made some bargains on the manufacturing to lower the costs, we'll see where it takes us. We will write a log as soon as we test the boards.
60 of them are incoming.
I just added the PCB and software repos.
Hi, I have gone though all the comments, you have made a great progress. I am myself interested in such projects can not continue due to other commitments. I hope, I will come up with more updates. However, you should visit https://apkallin1.com/
