Shitty Add-on v1.69bis Eagle library
a library for EAGLE users so they can get their shitty add-on
Public Chat
It's a shitty Add-on Library! for Eagle! Everyone gone done kicad, nobody done do eagle cad, so I done did it for y'all. this has both the badge and the add-on format. be sure to flip the SAO one to the rear of the card so it's set up right for manufacture Once/if I figure out how this works, I'll do the same in the template. if you use it, drop me a line. thanks!
shitty defcon add-on.lbr
Eagle CAD library with the shitty add-on 1.69bis in SAO and badge models.
- 23.74 kB - 05/07/2019 at 02:34
Download
babint wrote 06/23/2019 at 04:59 point
Downloaded the library but it looks like its the defcon 26 2x2 connector
