in collecting all the data we need is a type of sensor to read certain data needed for a room. But I don't think we need to worry about that because in this day and age a project called IoT has emerged that can quickly be built with sensors needed to check a room.
well in this project we will show you how easy it is to make a tool to monitor the conditions and conditions of humidity in a room using minimum software and hardware.
Alim Mussoni
YJ
Audrey Robinel
Ethan Durrant
sparks.ron
