Peeling off the bottom-up cutted copper tape ( 2nd version of the traces )
JPEG Image -
1.92 MB -
05/09/2019 at 11:29
Preview
Yup, we're all cleaned up here !
JPEG Image -
2.18 MB -
05/09/2019 at 11:29
Preview
Preparing the kapton protection on the plastic support to prevent burns like in the previous version ..
JPEG Image -
2.19 MB -
05/09/2019 at 11:29
Preview
Now onto peeling off only what's not traces :)
JPEG Image -
2.11 MB -
05/09/2019 at 11:29
Preview
Everything went quite well, but I scratched the kapton in some places ( staying focused on precise work for some hours is quite hard sometimes ) - also, there are missing trace(s) ( I think one or two little ones ) that I'd either re-cut & place manually or simply replace with a tiny wire ;p
JPEG Image -
2.05 MB -
05/09/2019 at 11:29
Preview
AkalisMask_v0.1a.ino
Full code for Akali's mask - needs a step-by-step debug ;p
ino -
18.50 kB -
05/09/2019 at 10:53
Download
AkalisMask_v0.1a_strippedDownDebug_mouthIdxIncreaseFromProgmemW.ino
Full code for Akali's mask - step-by-step debug: mouth cycling on button press ok
ino -
21.75 kB -
05/09/2019 at 10:53
Download
generateLedsArraysFromLayersShapes_latest.js
Latest version of the script that generates the Arduino progmem stuff when ran from within an Adobe Illustrator document: what it does is explained in more details in the logs ;)
javascript -
21.26 kB -
05/09/2019 at 10:52
Download
wipTimingsFromRoxanneStuff.js
you know how it is: you tell someone the best you can the way he/she can help you cut the code writing time by formatting some content in some manner .. and he/she does his/her best, but you indeed didn't explain youself very well ( even if providing code to better explain .. ), so now you know the why, here's how to get back from that time-sucking hole ..
javascript -
10.30 kB -
05/09/2019 at 10:52
Download
MOUTHOFFICIAL4.4-adjustedAfterHalfFailPlusRotatedBottomLeds_bottomLedRotated_waitingTesting_scriptable.ai
Final version of the leds placements for APA102C "chunks" from a bigger strip ( I wasn't confident enough in soldering bare APA102C so I opted for this - I guess another version on a "real" flexible pcb could really benefit from this .. and multiple layers would help simplifying the routing, which was done manually in Illustrator ;p )
postscript -
411.65 kB -
05/09/2019 at 10:49
Download
MOUTHOFFICIAL4.4-adjustedAfterHalfFailPlusRotatedBottomLeds_bottomLedRotated_waitingTesting_2dCaseLayers.ai
Previewing how to structure the cavities above the leds in 3d ( whose front side will be filled with 3d printed diffusers ) - could be used to cut layers of some material to test out the effect ( I didn't have time to yet .. )
postscript -
308.10 kB -
05/09/2019 at 10:49
Download
MOUTHOFFICIAL4.5-finallyWorkingWithRGBTesterCode_refiningStuffFromLessonsLearned_notScriptableYet.ai
Refined traces with the lessons learned from the original ones ( pads added for capacitors, as well as the option to provide power from the other side )
postscript -
546.45 kB -
05/09/2019 at 10:48
Download
IMG_8410.MOV
A quick preview of cycling through the different mouths, with a top made of painted plastic, scratched at the teeth contours ( was a failed test used for further testing ). no cavities underneath, reason why the light "bleed" onto closeby areas
quicktime -
49.16 MB -
05/09/2019 at 10:47
Download
Portable Network Graphics (PNG) -
184.65 kB -
05/09/2019 at 10:45
Preview
126.15 kB -
05/09/2019 at 10:45
Preview
292.52 kB -
05/09/2019 at 10:45
Preview
312.34 kB -
05/09/2019 at 10:45
Preview
188.29 kB -
05/09/2019 at 10:45
Preview
229.81 kB -
05/09/2019 at 10:45
Preview
185.64 kB -
05/09/2019 at 10:45
Preview
163.56 kB -
05/09/2019 at 10:45
Preview
245.18 kB -
05/09/2019 at 10:45
Preview
198.50 kB -
05/09/2019 at 10:45
Preview
256.69 kB -
05/09/2019 at 10:45
Preview
154.85 kB -
05/09/2019 at 10:45
Preview
74.62 kB -
05/09/2019 at 10:45
Preview
212.43 kB -
05/09/2019 at 10:45
Preview
280.49 kB -
05/09/2019 at 10:45
Preview
194.90 kB -
05/09/2019 at 10:45
Preview
13_finalInspectionBeforePrintingReferenceMapAndOntoCopperTapeCutter_rememberToCutCopperOnBottomToGetAutoStickyOnAlsoCutTransparentSupport.png
318.35 kB -
05/09/2019 at 10:45
Preview
111.12 kB -
05/09/2019 at 10:45
Preview
51.34 kB -
05/09/2019 at 10:45
Preview
112.30 kB -
05/09/2019 at 10:45
Preview
337.28 kB -
05/09/2019 at 10:45
Preview
315.78 kB -
05/09/2019 at 10:45
Preview
106.03 kB -
05/09/2019 at 10:45
Preview
179.13 kB -
05/09/2019 at 10:45
Preview
16.4_GeneratedDataNowSupportingRealtimeTogglingBetweenStatesAndActualTeethColorsIfUsedInArduinoCode.png
330.23 kB -
05/09/2019 at 10:45
Preview
506.21 kB -
05/09/2019 at 10:45
Preview
118.60 kB -
05/09/2019 at 10:45
Preview
106.69 kB -
05/09/2019 at 10:45
Preview
