Code
05/10/2019 at 22:33 • 0 commentsHere is the completed working code for a random pattern. Nothing special, not efficient or fast at all. But it needed to be done quick since it's a gift for my fathers birthday which is now...
#define MOS1 8 #define MOS2 9 #define MOS3 10 #define MOS4 11 #define DAT1 0 #define DAT2 1 #define DAT3 2 #define DAT4 3 #define DAT5 4 #define DAT6 5 #define DAT7 6 #define DAT8 7 #define OE1 A0 #define OE2 A1 #define LE1 A2 #define LE2 A3 void setup() { // mosfets pinMode(MOS1, OUTPUT); pinMode(MOS2, OUTPUT); pinMode(MOS3, OUTPUT); pinMode(MOS4, OUTPUT); // data pinMode(DAT1, OUTPUT); pinMode(DAT2, OUTPUT); pinMode(DAT3, OUTPUT); pinMode(DAT4, OUTPUT); pinMode(DAT5, OUTPUT); pinMode(DAT6, OUTPUT); pinMode(DAT7, OUTPUT); pinMode(DAT8, OUTPUT); // latch pinMode(LE1, OUTPUT); pinMode(LE2, OUTPUT); // disable outpputs pinMode(OE1, OUTPUT); pinMode(OE2, OUTPUT); digitalWrite(OE1, HIGH); digitalWrite(OE2, HIGH); } int data1[] = {0, 0, 0, 0}; int data2[] = {0, 0, 0, 0}; void loop() { // make new random data for (int i = 0; i < 4; i++) { data1[i] = int(random(256)); data2[i] = int(random(256)); } for (int x = 0; x < 10; x++) { for (int i = 0; i < 4; i++) { // enable outpputs digitalWrite(OE1, LOW); digitalWrite(OE2, LOW); // load data1 if (data1[i] % 2 == 0) { digitalWrite(DAT1, HIGH); } if (data1[i] % 3 == 0) { digitalWrite(DAT2, HIGH); } if (data1[i] % 4 == 0) { digitalWrite(DAT3, HIGH); } if (data1[i] % 5 == 0) { digitalWrite(DAT4, HIGH); } if (data1[i] % 6 == 0) { digitalWrite(DAT5, HIGH); } if (data1[i] % 7 == 0) { digitalWrite(DAT6, HIGH); } if (data1[i] % 8 == 0) { digitalWrite(DAT7, HIGH); } if (data1[i] % 9 == 0) { digitalWrite(DAT8, HIGH); } // latch digitalWrite(LE1, HIGH); delay(1); digitalWrite(LE1, LOW); // reset digitalWrite(DAT1, LOW); digitalWrite(DAT2, LOW); digitalWrite(DAT3, LOW); digitalWrite(DAT4, LOW); digitalWrite(DAT5, LOW); digitalWrite(DAT6, LOW); digitalWrite(DAT7, LOW); digitalWrite(DAT8, LOW); // load data2 if (data2[i] % 2 == 0) { digitalWrite(DAT1, HIGH); } if (data2[i] % 3 == 0) { digitalWrite(DAT2, HIGH); } if (data2[i] % 4 == 0) { digitalWrite(DAT3, HIGH); } if (data2[i] % 5 == 0) { digitalWrite(DAT4, HIGH); } if (data2[i] % 6 == 0) { digitalWrite(DAT5, HIGH); } if (data2[i] % 7 == 0) { digitalWrite(DAT6, HIGH); } if (data2[i] % 8 == 0) { digitalWrite(DAT7, HIGH); } if (data2[i] % 9 == 0) { digitalWrite(DAT8, HIGH); } // latch digitalWrite(LE2, HIGH); delay(1); digitalWrite(LE2, LOW); // reset digitalWrite(DAT1, LOW); digitalWrite(DAT2, LOW); digitalWrite(DAT3, LOW); digitalWrite(DAT4, LOW); digitalWrite(DAT5, LOW); digitalWrite(DAT6, LOW); digitalWrite(DAT7, LOW); digitalWrite(DAT8, LOW); // enable mosfet if (i == 0) { digitalWrite(MOS1, HIGH); delay(1); digitalWrite(MOS1, LOW); } else if (i == 1) { digitalWrite(MOS2, HIGH); delay(1); digitalWrite(MOS2, LOW); } else if (i == 2) { digitalWrite(MOS3, HIGH); delay(1); digitalWrite(MOS3, LOW); } else if (i == 3) { digitalWrite(MOS4, HIGH); delay(1); digitalWrite(MOS4, LOW); } // disable outpputs digitalWrite(OE1, HIGH); digitalWrite(OE2, HIGH); } delay(1); } }
If you want only one led to light up, you have to use modulo with prime numbers. Like this, when modulo 4 is zero, modulo 2 will always be zero too.
