Things used in this project
| Snips Voice Interaction Development Kit (Base Kit) | × 1 |
| Raspberry Pi 3 Model B | × 1 |
| Seeed ReSpeaker 2-Mics Pi HAT | × 1 |
| Seeed Grove - Temperature Sensor | × 1 |
| Seeed Grove - Relay | × 1 |
| Snips AIR | |
| Raspberry Pi Raspbian |
Story
Why Did We Build This?
From my personal experience, I've seen many people preparing for various linguistic test such as GRE, TOEFL, IELTS. They need a person to help them in memorizing and understanding the words.
Generally, when a person prepares for any such exams, they are in need of a person to check and correct if they make a mistake. With this solution, we can reduce the manpower by employing a voice assistant.
Hardware Build
First of all, I would like to thank SNIPS and SEEED for supporting this project with the amazing Snips Voice Interaction Development Kit (Base Kit), I really felt informative using this board and able to achieve some of the complex projects integrated within a PCB.
You can purchase the Snips Voice Interaction Base Kit for $115 and Snips Voice Interaction Satellite Kit for $85
Step 1: Getting Started with SNIPS
Before getting started, let's review what you'll need.
- Raspberry Pi 3B/B+ (Recommended) or Pi 2 Model B (Supported).
- Micro-USB Cable & Micro-USB power adapter for Raspberry Pi.
- Micro SD Card (Minimum 8 GB) - An operating system is required to get started. You can download Raspbian Stretch and use the guides for Mac OS, Linux and Windows In the Raspberry Pi website.
- A USB Keyboard & Mouse, and an external HDMI Monitor - we also recommend having a USB keyboard and mouse as well as an HDMI monitor handy.
- Internet connection (Ethernet or WiFi)
Assembled kit
Out of box
The Snips Voice Interaction Development Kits empowers users to jump start their development of voice interfaces and easily integrate the Snips AI Voice Platform with hardware. Snips runs on device, meaning all of your voice commands and data are processed locally rather than being sent to the cloud. This on-device processing results in a completely secure offline voice assistant that keeps your personal data private, as it should be.
The Voice Interaction Base Kit allows you to run the entire Snips AI Voice Platform. Powered by a Raspberry Pi 3 Model B+ and the ReSpeaker 2-Mics Pi HAT, it is capable of acting as your home smart speaker. Along with the kit comes a speaker, a Grove - Temperature & Humidity Sensor (SHT31), a Grove - Relay, and a pegboard to hang it on a wall or create a nifty stand.
But that's not all! The Voice Interaction Satellite Kit will extend your base station to reach each room of your house and allow you to interact with the hardware based on where you issue your commands!
This kit contains a Raspberry Pi3 B+ board, ReSpeaker 2-Mics Pi HAT, Grove – Relay, Grove - Temperature&Humidity Sensor (SHT31), Speaker 6 Ohm 2W, MicroSD Card, Power adapter with Micro USB connector, Grove cable x 2, Acrylic Base panel.
Assembly Steps: (Content from SNIPS)
The following picture is the overview of the assembly parts.
Here the assembly parts are mounted on the base panel.
Then, all the electronic parts are mounted on the board.
After that mount the Acrylic Protective cover on top of the Grove -Relay.
These 2 parts are used to make the Kit into a table stand.
This is how it looks when the above 2 parts are connected to the base panel.
Finally, you are ready to play with Snips.
The kit provides two ways of placement. It can either be placed on a horizontal surface as a stand or can be hung...
Rahul Khanna
Anton
Jamie
Dmitry
Brenda Armour
Having a personal English trainer is a game-changer, and with the advancements in technology, an AI Voice Assistant can provide just that! If you're looking to master English grammar, including tricky areas like reported speech, an AI Voice Assistant can be an invaluable resource. By interacting with this innovative technology, you can practice converting direct speech into reported speech with ease and precision. The AI Voice Assistant can simulate real-life conversations, allowing you to apply reported speech rules in various contexts. This personalized approach to learning English grammar ensures that you gain practical skills and build confidence in using reported speech accurately. Embrace the convenience and effectiveness of a Personal English Trainer through an AI Voice Assistant and take your language skills to new heights. Happy learning!
