The universal enigma engine seems to be working correctly
Here are a couple of posts with the current project status:
https://www.instagram.com/p/B2dJO-4n6Dr/
A project log for (AT) Mega Enigma, a 2560 Pro Mini Enigma Simulator
A minimalist 139x171x50mm Enigma Machine Simulator with working plugboard using an ATmega 2560 Pro Mini and a custom PCB.
Not bad for something that was not tested on a breadboard and designed with no schematic, in Fritzing. The PCB was laid out by connecting each lamp to its corresponding key, connecting 16 keys together to a common line and 16 leds together to a common line and connecting each lamp to the closest available pin. After everything was wired, an excel file was made with the pins each device was connected to.
They both look fantastic, been very exciting to see them develop over the last few months.
