The Arduinos and keyboards have been soldered. The Arduino Mega and the 16 Segment Displays have been installed on a socket. The Z30 is all soldered except for the displays, this board will be used to test the displays on-hand and then a set will be soldered.
One decimal point is upside down, its ok, its not soldered...
