With FlexPCB, custom-designed LED strip is feasible. Here is one with 5mm through-hole LEDs. It can be put on to my party hat.
The PCB is back.
JPEG Image - 268.80 kB - 06/06/2019 at 17:51
I would recommend using Surface mount LED's. The Though hole LED's should be fairly simple to solder though.
Philip Cox
Jacob.R.Jennings
Vikas V
Bess Ho
Yes, delete it Cancel
You are about to report the project "LED strip design with FlexPCB ", please tell us the reason.
