1Program the microcontroller
Flash the PIC using this compiled code.
2Get the printed circuit board
You can order it (for example at JLCPCB or ALLPCB) or make it yourself using these GERBER files.
3Solder the componentes
Do not solder the DE-15 connector nor the jack socket yet. Otherwise it will be difficult to solder the SCART wires.
4Cut a SCART cable into halves
You will only need one of the halves.
5Solder the SCART wires
The holes for the SCART wires are labeled E2,..,E21. Note than you don't have to solder all the SCART wires.
6Remove the nuts of the connectors
You won't need the nut of the jack socket till the last step.
7Solder the connectors
Solder the DE-15 connector and the jack socket. -
8Drill and cut the DE-15 enclosure
You can use this GERBER file to make two dummy PCBs that will help you to make the holes in the correct place as shown bellow:
9Step 9
Fit the adapter into the enclosure and screw the bolts.
10Step 10
Close the enclosure and put the nut back in the jack socket.
