The current specs of the robot is:
Estimated weight: 12.612 kg.
Maximum reach: 730 mm.
Estimated payload: 1 kg.
Virtual simulation using Matlab and RoboAnalyzer.
An attempt to design and build a 3D printable 6 axis robot that meets the industrial standard.
This looks awesome! Are you planning on providing the kinematics and code as open source?
I would love to try this out with your harmonic drive's. Keep up the great work!
