testing LED brightness
A project log for Designing a solar harvesting blinking gadget
Based on earlier solar harvesting projects I wanted to design a solar harvesting gadget
jasper-sikkenJasper Sikken 04/05/2021 at 18:400 Comments
Recently I realized that green LEDs are much brighter compared to red LEDs. For example for SML-LX0404SIUPGUSB RGB LED the luminous intensity is 30, 40, 20 mcd at 2mA for red, green, blue respectively.
Then I grabbed a red LED, which I thought was pretty bright (250mcd@20mA), because I selected it for my previous blinky circuit, and soldered it in series with a green LED that I recently selected (1400mcd@20mA), and guess what? The green LED was so much brighter.
And look at this, at 40uA, it is still pretty bright. Even though the forward voltage is a bit higher, about 2.2V vs. 1.7V for red, it is still much more efficient and the reason is that the human eye is most sensitive to green.
Then I ordered a bunch very bright green LEDs from Wurth
I set the current only 10uA.
Compared to a smartphone these LEDs at 10uA are very visible. I really need to design a solar powered blinky with green LEDs.
Rich text editor
