Hackaday.io Hackaday.io
Sign up Log in
TiwlaTiny Socializing Machine
TiwlaTiny
This is IOT family member of Tiwla.com.
Socializing machine organize spiritual feeling with your friends.
alpertandoganalpertandogan
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
0 followers
  • Description
  • Details
  • Files 8
    • View all
  • Components 3
    • View all
  • Logs 4
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
204
0
0
0
Team (1)
  • alpertandoganalpertandogan
Join this project's team
  • Home Page
  • Onshape 3d Desing
hardware
ongoing project
cloud Socializing
This project was created on 05/25/2019 and last updated 7 years ago.
Description
Socializing machine projectTiwlaTiny This is IOT family member of Tiwla.com.Socializing machine organize spiritual feeling with your friends.TiwlaTiny is a machine works with tiwla.com. It gives a response from site using RGB led ring when users receive notification User also can send spiritual feeling Color to friends. It also one touch button to give a response back and on and off RGB ring.This device is connect securly to internet directy using WIFI. It wait realtime notification response from site www.tiwla.com
Files
JPEG Image - 532.18 kB - 05/25/2019 at 09:08
Preview
JPEG Image - 515.66 kB - 05/25/2019 at 09:08
Preview
Using OnShape made model of TiwlaTiny
JPEG Image - 539.36 kB - 05/25/2019 at 09:08
Preview
After 3d Print of TiwlaTiny using Car Paint Paste make a good surface.
JPEG Image - 486.76 kB - 05/25/2019 at 09:08
Preview
Using RTV2 Silicone Mold.
JPEG Image - 474.23 kB - 05/25/2019 at 09:08
Preview
View all 8 files
Components
  • 1 × NodeMCU V3 Lua esp8266 development board
  • 1 × RGB LED ring using WS2812 Rgb Led
  • 1 × TTP223 Capacitor type Single Channel Switch Sensor Touch Sensor
Project Logs
Collapse
  • TiwlaTiny Working Video
    alpertandogan • 06/11/2019 at 15:12 • 0 comments
    TiwlaTiny setup using QRcode on back of device and box.
    This is working one.
  • TiwlaTiny Electronic Parts
    alpertandogan • 06/11/2019 at 14:28 • 0 comments
    NodeMCU V3 Lua
    Patch cables
    Frame Epoxy
    Front Plexiglass transparent  logo print on using UV printer.
    Back Plexiglass black one.
    Touch button for power on off and response back to host.
  • TiwlaTiny Body 3d Print and Mold Prepation with RTV2 for Epoxy Resin
    alpertandogan • 05/25/2019 at 10:04 • 0 comments
    Print  3d model using  3d Plus Ronin V4 3 with PLA
    Prepare parts surface using polyester putty and emery. Acrylic spray paint for finishing.
    Make mold using RTV2 silicone.
    Make part using Epoxy Resins and beach sand
    Epoxy Part and Acrylic Plexiglass for up and down cover of TiwlaTiny
  • TiwlaTiny Body Modelling
    alpertandogan • 05/25/2019 at 09:54 • 0 comments
    TiwlaTiny
    First We made body prototype TiwlaTiny
    3d Modeling using www.onshape.com
    https://cad.onshape.com/documents/08a6faa2a466a2736ce4a0aa/w/63682449dc4c47c7a51956c6/e/563d1551c68d441343772438
View all 4 project logs
Log In/Sign up to comment
Sign up with Github
OR
The 2018 Hackaday Prize
Do you wanna feed your pets from outdoor? I have made a feeding machine which can be controlled on the browser using smartphone.
Project Owner Contributor
Feeding cat remotely using smartphone with obniz
sana-aSana A
Hackaday Prize 2020
A simple 3D printed model which helps students with cerebral palsy draw and paint.
Adaptive Drawing Device
christopher-sweeneyChristopher Sweeney
Exploring the potential of the AS7341 as a low cost PAR meter using multiple linear regression and machine learning.
PAR Buddy - using the AS7341 as a PAR meter
happydaymjohnsonhappyday.mjohnson
I made 3D printed Lithophane backstage passes for the Whole Earth Festival. Here is a box I made to hold and illuminate my laminate.
Lithophane Backstage Pass Lightbox
shankzshankz
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "TiwlaTiny Socializing Machine", please tell us the reason.
Send message
Remove Member
