Idler Assembly.pdf
2 Assembly of three Idlers which are at the end of the axes
Adobe Portable Document Format -
565.02 kB -
09/04/2019 at 03:48
Preview
X and Y Motor Assembly.pdf
3 Assembly of Motors for x and y axes
427.75 kB -
09/04/2019 at 03:47
Preview
Brass Bracket.step
Brass Bracket to hold the shaft that turns the slave pulley.
step -
29.71 kB -
09/04/2019 at 03:14
Download
Shaft - Shaft 5 x 469 mm.step
5 mm diameter by 469mm shaft. Stainless or steel.
step -
6.27 kB -
09/04/2019 at 02:44
Download
Shaft Coupler - Shaft Coupler.step
Coupler to attach the Y axis motor to the slave y axis. Made of aluminum with setscrews.
step -
32.68 kB -
09/04/2019 at 02:42
Download
Black 3D printed bracket.stl
Brackets to hold x axis to y axis sled. Need 4 pcs.
Standard Tesselated Geometry -
89.54 kB -
09/04/2019 at 02:22
Download
Black 3D Printed bracket.step
step -
2.84 MB -
09/04/2019 at 02:22
Download
Brackets - X Motor bracket with cable chain holder.step
This is the second X axis bracket. It has a bend in it and was made with sheet metal cad.
step -
80.47 kB -
09/03/2019 at 03:13
Download
Brackets - Motor bracket.step
This bracket is used to hold the Y axis motor to the Y axis on the right side. It is also the front bracket for the X axis motor.s
step -
63.00 kB -
09/03/2019 at 03:13
Download
Brackets - Flat pattern of Motor bracket with cable chain holder.dxf
This is the flat pattern for the X Motor bracket with cable chain holder. The bend lines should be erased or cut at very high speed to be a guide for line bending.
AutoCAD DXF -
57.03 kB -
09/03/2019 at 03:13
Download
X axis bracket.stl
Bracket to hold the x axis to the sled.
89.54 kB -
08/24/2019 at 13:22
Download
Machined Idler Spacer.step
eeIdeal spacer is just smaller than the space and rides on bearing instead of the pulley wall. We machined this on our lathe but it could be 3D printed.
step -
8.58 kB -
07/27/2019 at 15:00
Download
Pulley Holder.step
Bracket to hold the pulleys for the return loop for the belt. Four holes to attach to the channel and 2 holes for machine screws to hold the the pulleys. Need at least 4 and possibly 6 if both y axes have motors.
step -
46.73 kB -
07/27/2019 at 12:14
Download
Sled Bottom.step
Bottom laser cut piece for slider mount. Need 2 pcs
step -
235.64 kB -
07/21/2019 at 19:55
Download
Sled Top.step
Top laser cut acryclic piece for slider mount. Need 2 pcs.
step -
254.69 kB -
07/21/2019 at 19:54
Download
EndstopSensorHolder.step
3D printed part that holds the endstop sensor. Need 4 pcs.
step -
226.77 kB -
07/21/2019 at 19:54
Download
PNP Instructions Frame and Slider assembly.pdf
1 First two steps in pnp assembly. Need EndstopSensorHolder x 4, Sled Top x 2 and Sled Bottom x 2 and puchased parts.
1.18 MB -
07/21/2019 at 19:51
Preview
McuOpenPnP Bill of Material.xlsx
Excel version of the purchased BOM
sheet -
15.35 kB -
06/16/2019 at 14:59
Download
McuOpenPnP Bill of Material.ods
Open version of BOM
spreadsheet -
24.53 kB -
06/16/2019 at 14:59
Download
