Hackaday.io Hackaday.io
Sign up Log in
RAINBOW-FLEX-RAPTOR
Adding a RGB touch to a flexy raptor
aubinrabouanaubinrabouan
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
2 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
215
0
2
4
Team (1)
  • aubinrabouanaubinrabouan
Join this project's team
hardware
ongoing project
FLEXI RAPTor led pcb rainbow
This project is submitted for
  • Flexible Circuit Contest
This project was created on 05/25/2019 and last updated 7 years ago.
Description
I 3d printed this Flexy raptor https://www.thingiverse.com/thing:2901355 and want to add rgb leds for display. I did a first version to validate the concept using standart LEDs from a strip. The rendering is awesome but it added a lot af stiffness to the part and the placing and wiring is quite difficult. power and a arduino nano are comming out of the tail.The next version will use a flex PCB to add more LEDs, incorporate the micro controller to the PCB. 2 power will be possible, the first if a micro-usb cable from the tail, the second il from the hand to be able to run a cable through a rod when it lays on.
Details
Log In/Sign up to comment
Sign up with Github
OR
Inspired from the PCB version
Project Owner Contributor
NE555 Christmas Tree
vincentmakesvincentmakes
A star shaped PCB with 10x LEDs on each side, a programmable ATMEGA328, and micro USB power option
“The Star” 20x LED decoration
neil-parrisNeil Parris
This is certainly inspirational, I detail the full making steps of a cool glowing Magic LED Cube, all necessary files are included.
Glowing RGB LED Magic Cube (WS2812)
diy-guy-chrisDIY GUY Chris
Full-Size Working Replica of Mega Man's Mega Buster
arnov-sharmaArnov Sharma
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "RAINBOW-FLEX-RAPTOR", please tell us the reason.
Send message
Remove Member
