Over The Air Updates in newest Version
08/06/2020 at 14:23 • 0 comments- Over The Air Updates: From now on Releases contain two images, the full image thats to be flashed via cable and the OTA update image.
- Expose OTA File Upload in Web Interface
- Network: Support custom Hostnames (new
hostname
key in config.json, see example) - Touch: Add Options to invert X/Y-Axis for the Touch device since some cheaper IL9341 Units are weird up wrong (see Readme)
Precompiled Binaries & Remote Configuration
02/13/2020 at 19:40 • 0 commentsPublished pre-compiled binaries that can be flashed onto ESP32 devices without compiling.
Initial configuration is done by connecting to an AP spawned by ESP32 and setting it up to connect to the real Wifi.
Afterwards configuration can be done through the browser.
UX Improvements for Multi-Device Scenes
08/20/2019 at 19:34 • 0 commentsMulti-devices scenes are now shown by a visual indicator which can be tapped. Using long-press has been proven to cumbersome on some of the touch-hardware (lots of misses).
Partially activated scenes are also shown by changing the color of the text label. -
HomeKit Integration
05/31/2019 at 19:56 • 0 commentsAdding HomeKit Integration to HomePoint. Since there is no way to interact with other HomeKit Devices on a network, HomePoint will allow users to toggle switches, that can be setup to automate other devices inside the Home App on iOS.
