To do list:
- Hardware
- Physical
- Design - Done
- Buy - Done
- Build - Done
- Improvements - in progress
- Electronics
- Design - Done
- Order - Done
- Assemble - Done
- Physical
- Software
- Done and tested
Already identified improvement points:
- PWM boost circuit does not work, currently not an issue as the specified fan accepts a 3.3V signal
- Change grill resting points from 4 to 3 so the hole accuracy does not matter that much (currently with 4 slightly wonky drilled holes the grill seesaws)
- Fix uneven burn in the coal basket
- Coal chute
- Redo temperature ramp -> turn on fan for 30 seconds and then off and wait
- Temperature offset calibration functionality
- Open lid detection
- Probably more to come :)
HackersHub
Aleksander Kawęczyński
Lance
Chris Slothouber
Jonathan
