It is basically a fancy wire
A microstrip to waveguide transition used for X-band waveguides. Manufactured with Oshpark FlexPCB
WR90_microstrip-B.Cu.gbrx-gimp-gbr - 61.90 kB - 05/29/2019 at 06:23 |
WR90_microstrip-F.Cu.gbrx-gimp-gbr - 93.08 kB - 05/29/2019 at 06:23 |
WR90_microstrip.drldrl - 5.45 kB - 05/29/2019 at 06:23 |
WR90_microstrip-B.SilkS.gbrx-gimp-gbr - 287.00 bytes - 05/29/2019 at 06:23 |
WR90_microstrip.kicad_pcb-bakkicad_pcb-bak - 207.92 kB - 05/29/2019 at 06:23 |
So fairly certain this passes DRC since I ran it through OSH Park's initial input
TODO: remove soldermask and realign those large screw holes
Pretty sure the bulk of the basic design of this project is done. I really need to try and do more of these. https://twitter.com/moddedLimes/status/1133453412291497985
