MSL to WR90/WG16
A microstrip to waveguide transition used for X-band waveguides. Manufactured with Oshpark FlexPCB
Public Chat
You can see it being built in this screwy twitter thread https://twitter.com/moddedLimes/status/1133453412291497985
If this works with the first revision, I will be excited, otherwise I need to get out the exacto knife and copper tape.
It is basically a fancy wire
WR90_microstrip-B.Cu.gbr
x-gimp-gbr - 61.90 kB - 05/29/2019 at 06:23
Download
WR90_microstrip-F.Cu.gbr
x-gimp-gbr - 93.08 kB - 05/29/2019 at 06:23
Download
WR90_microstrip.drl
drl - 5.45 kB - 05/29/2019 at 06:23
Download
WR90_microstrip-B.SilkS.gbr
x-gimp-gbr - 287.00 bytes - 05/29/2019 at 06:23
Download
WR90_microstrip.kicad_pcb-bak
kicad_pcb-bak - 207.92 kB - 05/29/2019 at 06:23
Download
View all 14 files
  • DRC done
    Jordan05/29/2019 at 06:27 0 comments
    So fairly certain this passes DRC since I ran it through OSH Park's initial input
    TODO: remove soldermask and realign those large screw holes
View project log
  • 1
    Buy flex PCB from OSH Park
  • 2
    Solder SMA connector
  • 3
    Connect adapter to 3D printed waveguides
View all 4 instructions
Jordan wrote 05/29/2019 at 06:45 point
Pretty sure the bulk of the basic design of this project is done. I really need to try and do more of these.  https://twitter.com/moddedLimes/status/1133453412291497985
