paint job and final assembly
08/29/2020 at 20:52 • 0 commentspainted all the parts and assembled the whole machine afterwards. Amazingly how a few sprays of paint increase the look.
Assembly of housing and electronics
08/19/2020 at 14:26 • 0 commentsAssemble housing and electronics
Mechanical assembly of C-Sample
08/11/2020 at 04:57 • 0 commentsMechanical assembly of the C-Sample is nearly finished
Finished the Cad of the C-Sample
08/05/2020 at 07:32 • 0 commentsFinished the CAD Work. Benchtop is now standard and the wall-mount optional. Assembly will start soon
B-Sample disassemble
08/01/2020 at 12:12 • 0 commentsDisassembled the whole machine. The parts will be used for the C-Sample
Finished the B-Sample
07/31/2020 at 12:10 • 0 commentsFinished the Housing of the B-sample and testet the whole machine.
The B-Sample is thus completed and will be disassembled to reuse the parts on the C-Sample.
Also made test for the chamfered housing Parts for the C-Sample.
Electronics finished, Testing Controller Plates
07/27/2020 at 05:42 • 0 commentsBy adding the second Controller, the Electronics are now finished. Tried different types of Plates for the Controller. My favorite is the plastic one and with below 50 C at the frame, it will not melt.
Next step will be the completion of the housing, testruns and documentation.
Pre Assemble of Electronics & Housing
07/23/2020 at 06:18 • 0 commentsAssembled the heating clips , isolation, parts of the housing and testet the electronics. The sidepanel with the controller will be changed to a smaller one in the next building session. The solution with one Controller plus SSR will also be replaced with two controllers only and their internal relais. See the MIRO Page for details: https://miro.com/app/board/o9J_kpTbPsU=/
B-Sample Mechanical Assembly finished
07/19/2020 at 10:10 • 0 commentsMechanical Assembly of the B-Sample nearly completed. Welded the Frame, tested different configurations for the lever arm, tested the Rod-Plunger and inserted coupling for the mold.
Check out MIRO and our Instagram Account for more details. https://miro.com/app/board/o9J_kpTbPsU=/
Work on B-Sample
07/14/2020 at 12:30 • 0 commentsWe finished the A-Sample, made tests. The Machine works good so far.
Now we are in the building-phase of the B-Version
