Brake Bar.stl
Standard Tesselated Geometry -
49.20 kB -
08/19/2019 at 22:18
Download
Platform for Electronics.stl
52.04 kB -
08/19/2019 at 22:17
Download
Washer.stl
96.27 kB -
08/19/2019 at 22:16
Download
Spacer 0.5mm.stl
It prevents contact between stators and rotors.
70.20 kB -
08/19/2019 at 22:14
Download
Spring Lock (Counter to Rotor 1).stl
400.38 kB -
08/19/2019 at 22:13
Download
Spring Lock (Rotor 1).stl
482.60 kB -
08/19/2019 at 22:12
Download
Magnets Housing for Rotor 3.stl
539.34 kB -
08/19/2019 at 22:02
Download
Magnets Housing Right for Rotor 2.stl
538.56 kB -
08/19/2019 at 22:01
Download
Magnets Housing Left for Rotor 2.stl
538.56 kB -
08/19/2019 at 22:01
Download
Magnets Housing for Rotor 1.stl
538.95 kB -
08/19/2019 at 21:59
Download
Body Case Cover.stl
Aside from as a cover, it holds the case and shaft stationary.
287.48 kB -
08/19/2019 at 21:52
Download
Counter to Rotor 1.stl
It houses the Brake Bar and makes the torsion spring engaged in a counter-clockwise direction.
964.83 kB -
08/19/2019 at 21:19
Download
Bushing.stl
It holds the Rotor 1 in place and acts as a stopper so that Rotor 1 and "Counter to Rotor 1" will rotate counter-clockwise together.
202.33 kB -
08/19/2019 at 21:03
Download
Lock.stl
It holds all major components in place.
2.46 MB -
08/19/2019 at 21:01
Download
Cover to Rotor 1.stl
It serves as cover to Rotor 1 and holds the "Counter to Rotor 1" in place.
132.21 kB -
08/19/2019 at 20:57
Download
Body Case.stl
It serves as a housing for electronic components and as a handle for the user when cranking.
1.14 MB -
08/19/2019 at 20:55
Download
Fastener and Cover to Rotors & Stators.stl
This holds the Rotor 1, Rotor 2 and Rotor 3 altogether.
219.71 kB -
08/19/2019 at 20:52
Download
Stator 2.stl
This houses the coils of copper wire and in between of Rotor 1 and Rotor 3.
183.68 kB -
08/19/2019 at 20:50
Download
Stator 1.stl
This houses the coils of copper wire and in between of Rotor 1 and Rotor 2.
183.68 kB -
08/19/2019 at 20:46
Download
Rotor 3.stl
Left side of Rotor 2
1.39 MB -
08/19/2019 at 20:36
Download
Rotor 2.stl
Middle rotor where the left and right housing magnets are attached.
3.84 MB -
08/19/2019 at 20:34
Download
Rotor 1.stl
This is an assembly that acts as a rotor and houses the torsion spring.
3.77 MB -
08/19/2019 at 20:29
Download
Shaft.stl
Holds components and hollow at the center to house copper wires.
540.32 kB -
08/19/2019 at 20:24
Download
