Little design change
06/02/2019 at 13:13 • 0 commentsI tried to build a mask with foam, I had in my workshop, but it did not block all the daylight. So I decided to buy a pair of this sleeping mask's for 6 Euros and to modify them. Now I have to wait till Wendsday.
RGB Led test with the Arduino Pro Micro
06/01/2019 at 17:39 • 0 commentsA simple sketch to test the RGB LES's
Looks promising
Driver Electronic For The LED's
05/31/2019 at 13:43 • 0 commentsFour Bc337 transistors to power the LED's. The current per color is 40mA, so I had to use these to not kill the Arduino outputs.
Here a small color test with the dot pattern.
And this will be the first test setup to control the LED's
The first parts
05/30/2019 at 19:17 • 0 commentsI used a laser cutter to build the first parts of the mask. So I can check if the Led's will fit and to see, what I will see in the mask.
3d Visualisation
05/30/2019 at 19:12 • 0 commentsHere are the first design test.
