PCB V-Cutter/Groove/Scores
Cutting V-scores in PCBS for cheaper panelization.
I wanted to make PCB V-Cutter/Groover to save some money on PCB manufacturing. This machine will cut v-scores in a PCB. The PCB V-Cutter/Groover uses a 30-degree v-cutting blade.
There are still a few issues with the machine that is been worked out.
StanislavJochman wrote 07/24/2019 at 13:57 point
What type of blade do you use. Can you post some link where to get it? It is interesting project and I wanted to try it out.
Best Regards
Stanley
Tinkers Projects wrote 09/30/2019 at 10:49 point
sorry just saw this
i ordered the blades from https://keen-edge.en.alibaba.com/
v cutter carbide 28x2x10x30°x32T
i have been working on a upgrade machine but have been getting stack with the small blades. i'm also fixing up my CNC to make some of the parts.
if you have more questions let me know :)
Mike Szczys wrote 06/04/2019 at 15:35 point
This is really cool. More details, please!
Tinkers Projects wrote 06/06/2019 at 06:44 point
i wanted to make a prototyping PCB for SMD components for bread boards but the quote i got for them to v-score 10 PCBs was about $260USD when i can get it for $5USD. i was hopping to make this to save some money.
its still a working progress, working out some problems like mounting the blade with not much movement. i think i will need to completely rethink how the motor is mounted and connects to the blade.
