Polyline Offset
Writing C code to offset a polyline
0 followers
It not as simple as it first appears!
Scope
The scope of this project is to document the coding of a rather complex problem.
Basic Code
To begin I need:
  • a "segment" intersection routine
  • an offset routine
  • some test data
I have decided to truncate intersection "rays" in the basic code.
Note: a segment is line bounded by two points while a ray is an infinitely long line.
Resolving Cross-Overs
Resolving cross-overs can wait until the basic code works  as well as it can.
Initial Experiments
Initially to test the two main routines I built a program that steps through increasing angles for two joined segments:
Here is the first case where the offset segments intersect:
Note: the white polyline is the original polyline and the red polyline is the offset polyline.
Here is the second case where the offset polylines intersect because I have extended the offset segments the offset distance:
Here is the third case where the intersection exceeds the extended offset segment. In this case I have truncated the offset polyline:
This truncated offset polyline is fine for CNC mill or laser cutting applications.
The last case is problematic:
I have to either accept this or a ray intersection.
After a lot experimentation, I decided to accept the ray intersection.
A final case to consider is co-linear segments. The two spikes are co-linear segments:
Next Set of Experiments
Here is my test data (the white closed polyline) for the next set of experiments:
For this experiment I filtered the original (i.e. the white polyine) for near co-linear segments and very short segments. Although the original polyline appears symmetrical, the location of the points are not.
Hers is the contraction case:
If I expand or contract the original polyline sufficiently problems appear:
Note the offset polyline cross-over.
And:
In this case the offset polyline has reversed direction. The offset polyline is also distorted due to the order of the offset point intersection truncation.
Status
At this point of time I have basic working code. There is potential to improve the code by resolving cross-overs and taking another approach to ray truncation.
AlanX
PolyLineOffset.run
- 30.56 kB - 06/17/2019 at 12:57
Download
libezx.a
x-archive - 28.44 kB - 06/16/2019 at 09:14
Download
ezx_graphics.pdf
Adobe Portable Document Format - 92.72 kB - 06/16/2019 at 09:14
Preview
ezxdisp.h
x-chdr - 4.33 kB - 06/16/2019 at 09:14
Download
PloyLineOffset.c
text/x-csrc - 7.74 kB - 06/16/2019 at 09:13
Download
  • Cross-Over Removal
    agp.cooper • 06/18/2019 at 10:28 • 0 comments
    Cross-Over Removal
    Added code to remove co-linear points (spikes) and cross-overs. While cross-over removal is rather ambiguous (i.e. which is the cross-over and which is the polyline?). Rather than get too "deep", I just decided to limit the search to only half of the polyline (by point count). Here is the expansion case, before:
    and after:
    Here is the contractions case, before:
    and after:
    Well, that just about does it.
    AlanX
  • Basic Code
    agp.cooper • 06/08/2019 at 03:06 • 0 comments
    Basic Code
    The basic code is not too bad.
    Here is my segment intersection routine:
    int intersect(
      double px0,double py0,double px1,double py1,
      double px2,double py2,double px3,double py3,
      double *px,double *py)
      double det,s,t;
      // Test if co-linear
      det=(px3-px2)*(py0-py1)-(px0-px1)*(py3-py2);
      if (fabs(det)>1e-12) {
        // Find ray intersection
        s=((px1-px0)*(py0-py2)-(py1-py0)*(px0-px2))/det;
        t=((px3-px2)*(py0-py2)-(py3-py2)*(px0-px2))/det;
        *px=px0+t*(px1-px0);
        *py=py0+t*(py1-py0);
        if ((s>=0.0)&&(s<=1.0)&&(t>=0.0)&&(t<=1.0)) {
          // Segment Intersection
          return 1;
        } else {
          // Ray Intersection
          return 2;
      } else {
        // In my special case (for a polyline), I want the last point.
        *px=px3;
        *py=py3;
        return 0;
    The offset routine, considers the cases returned from the intersection routine:
    int makeOffset(
      double x1,double y1,double xc,double yc,double x2,double y2,double Offset,
      double *xi1,double *yi1,double *xi2,double *yi2)
      double dx1,dy1,dl1,xo1,yo1,xc1,yc1;
      double dx2,dy2,dl2,xo2,yo2,xc2,yc2;
      double xi,yi;
      int Test;
      // Segment lengths
      dx1=xc-x1;
      dy1=yc-y1;
      dl1=sqrt(dx1*dx1+dy1*dy1);
      dx2=xc-x2;
      dy2=yc-y2;
      dl2=sqrt(dx2*dx2+dy2*dy2);
      if ((dl1>1e-12)&&(dl2>=1e-12)) {
        dx1=dx1/dl1*Offset;
        dy1=dy1/dl1*Offset;
        dx2=dx2/dl2*Offset;
        dy2=dy2/dl2*Offset;
        xo1=x1-dy1;
        yo1=y1+dx1;
        if (Offset>=0.0) {
          xc1=xc-dy1+dx1;
          yc1=yc+dx1+dy1;
          xc2=xc+dy2+dx2;
          yc2=yc-dx2+dy2;
        } else {
          xc1=xc-dy1-dx1;
          yc1=yc+dx1-dy1;
          xc2=xc+dy2-dx2;
          yc2=yc-dx2-dy2;
        xo2=x2+dy2;
        yo2=y2-dx2;
        Test=intersect(xo1,yo1,xc1,yc1,xc2,yc2,xo2,yo2,&xi,&yi);
        if (Test==1) {
          // Segment Plus Offset Intercept
          *xi1=xi;
          *yi1=yi;
          *xi2=xi;
          *yi2=yi;
          return 1;
        } else if (Test==2) {
          double area=((y1-y2)*(xc-x2)-(yc-y2)*(x1-x2));
          if (((area<0)&&(Offset<0))||((area>0)&&(Offset>0))) {
            // External Ray Intercept (use truncated offsets)
            *xi1=xc1;
            *yi1=yc1;
            *xi2=xc2;
            *yi2=yc2;
            return 2;
          } else {
            // Internal Ray Intercept (use intercept)
            *xi1=xi;
            *yi1=yi;
            *xi2=xi;
            *yi2=yi;
            return 3;
        } else {
          // Co-linear Intercept
          *xi1=xi;
          *yi1=yi;
          *xi2=xi;
          *yi2=yi;
          return 4;
      return 0;
    One problem with the offset code is what to do with very short segments ?
    My solution filter the polyline for:
    • segments (points) that are nearly co-linear,
    • segments that are very short.
      // Filter Points (Open Polyline)
      Test=true;
      while (Test) {
        Test=false;
        int count=0;
        for (i=0;i<=N;i++) {
          count++;
          if (count>=3) {
            double area=fabs((Y[i-1]-Y[i-2])*(X[i]-X[i-2])-(Y[i]-Y[i-2])*(X[i-1]-X[i-2]));
            double length=sqrt((Y[i]-Y[i-2])*(Y[i]-Y[i-2])+(X[i]-X[i-2])*(X[i]-X[i-2]));
            if ((length*fabs(Offset)>area*100)||(fabs(Offset)>length*10)) {
              D[i-1]=true;
              Test=true;
              count=1;
        int j=0;
          if (!D[i]) {
            X[j]=X[i];
            Y[j]=Y[i];
            D[j]=false;
            j++;
        N=j-1;
    Finally the make Polyline Offset code:
      // Polyline Offset
      x1=X[N-2];
      y1=Y[N-2];
      xc=X[N-1];
      yc=Y[N-1];
      x2=X[0];
      y2=Y[0];
      makeOffset(x1,y1,xc,yc,x2,y2,Offset,&xc1,&yc1,&xc0,&yc0);
      NT=0;
      XT[NT]=xc0;
      YT[NT]=yc0;
      NT++;
      for (i=0;i<N;i++) {
        i1=(i+N-1)%N;
        ic=(i+N)%N;
        i2=(i+N+1)%N;
        x1=X[i1];
        y1=Y[i1];
        xc=X[ic];
        yc=Y[ic];
        x2=X[i2];
        y2=Y[i2];
        ezx_line_2d(disp,width/2+(int)(scale*x1),height/2-(int)(scale*y1),width/2+(int)(scale*xc),height/2-(int)(scale*yc),&ezx_white,1);
        Test=makeOffset(x1,y1,xc,yc,x2,y2,Offset,&xc1,&yc1,&xc2,&yc2);
        if (Test==1) {
          // Normal Intercept
          ezx_line_2d(disp,width/2+(int)(scale*xc0),height/2-(int)(scale*yc0),width/2+(int)(scale*xc2),height/2-(int)(scale*yc2),&ezx_red,1);
          XT[NT]=xc2;
          YT[NT]=yc1;
          NT++;
          // Truncated Intercept
          ezx_line_2d(disp,width/2+(int)(scale*xc0),height/2-(int)(scale*yc0),width/2+(int)(scale*xc1),height/2-(int)(scale*yc1),&ezx_red,1);
          ezx_line_2d(disp,width/2+(int)(scale*xc1),height/2-(int)(scale*yc1),width/2+(int)(scale*xc2),height/2-(int)(scale*yc2),&ezx_red,1);
          XT[NT]=xc1;
          YT[NT]=yc1;
          NT++;
          XT[NT]=xc2;
          YT[NT]=yc2;
          NT++;
        } else if (Test==3) {
          // Ray Intercept
     ezx_line_2d(disp,width/...
View all 2 project logs
