PVC Pipe 1:2" Flange Spacer Kit.svg
Use this set of spacers with a white 3" PVC wye. The PVC fittings are slightly smaller than the ABS fittings. The holes are spaced for 1/2" NPT pipe flange.
svg+xml - 21.76 kB - 01/08/2020 at 19:15
Preview
ABS Pipe 3:4" Flange Spacer Kit.svg
Use this set of spacers with a black 3" ABS wye. The ABS fittings are slightly larger than the PVC fittings. The holes in this kit are spaced for 3/4" NPT pipe flange.
svg+xml - 21.32 kB - 01/08/2020 at 19:15
Preview
ABS Pipe 1:2" Flange Spacer Kit.svg
Use this set of spacers with a black 3" ABS wye. The ABS fittings are slightly larger than the PVC fittings. The holes in this kit are spaced for 1/2" NPT pipe flange.
svg+xml - 20.92 kB - 01/08/2020 at 19:15
Preview
Trash printer extruder B1 (new hex).svg
svg+xml - 1.92 kB - 12/28/2019 at 21:35
Preview
three prong coupler spider2 slightly smaller.svg
svg+xml - 3.74 kB - 12/28/2019 at 21:35
Preview
Trash printer extruder T1 new angle.svg
svg+xml - 2.86 kB - 12/28/2019 at 21:35
Preview
Trash printer extruder T2 larger hole2.svg
svg+xml - 1.67 kB - 12/28/2019 at 21:35
Preview
Trash printer extruder B6.svg
svg+xml - 1.90 kB - 12/28/2019 at 21:35
Preview
Trash printer extruder B7.svg
svg+xml - 1.86 kB - 12/28/2019 at 21:35
Preview
Trash printer extruder B4.svg
svg+xml - 2.32 kB - 12/28/2019 at 21:35
Preview
Trash printer extruder B3.svg
Preview
Trash printer extruder B2.svg
svg+xml - 2.33 kB - 12/28/2019 at 21:35
Preview
Trash printer extruder B5.svg
Preview
