Project Well Received
A project log for Spectrum Analyser Code
Code for a spectrum analyzer.
agpcooperagp.cooper • 12/04/2016 at 00:39•0 Comments
I am a little surprised that the project has done so well. But then who would not be interested in a "Spectrum Analyser". It sounds so geeky!
In essence I had partially developed the code for another task and just saw the opportunity for a quick project.
Project logs are a little hard for a novice to follow if they just want to build one, as a log is about the journey rather than the destination. Often just a sentence from someone else's journey is all you need to solve a problem with your project.
So I thought I would post some step by step instructions (well not quite that detailed).
Regards AlanX
