I created and uploaded several important files and updated the documentation today. You'll see PDFs in the "files" section of this project here on hackaday,io, and the similar updates in Github.
- Schematic
- BOM
- Code plan for reading and writing the cores
- Development plan
- Electrical Block Diagram
- Software Block Diagram
- Manufacturing Considerations
- And licensing and permissions analysis of everything I'm making use of
I also added an STL of the stylus, designed with Onshape.
And finally the code that has been updated to show the symbols on the LED matrix.
