No more blinking leds for you!
For now this is just an idea for a Macrofab Contest entry. I'm not yet sure if I want to try making this.
High voltage scares me. And I don't even know how to generate it. This one is way out of my comfort zone.
If anyone has any idea, let me know.
Thanks for the suggestion. Really appreciate it, as this is really way out of my area of expertise.
Seconded - a multi-stage charge pump is definitely the way to go.
Oh I love this. Quick implementation idea. First use a boost converter to bring the 3.3V up as much as possible than an H-bridge type switcher into a diode -capacitor voltage multiplier. The H-bridge switch would need a clock, let's use SCL for that. First the Add-on sits there doing nothing until the badge tries to talk to it, which starts building up the voltage until it is high enough to feed it into the GPIOs.
#not_a_badge
